Windchill Risk & Reliability (or WQS) connection with Silicon Expert database
Is there a way to connect the Windchill Risk & Reliability (or WQS) tool to Silicon Expert database in order to pre-fill most of the component parameters (Thermal resistance, voltage rating etc…)?
Is the built-in database is up to date?
Is there a tutorial to build automatically a board assembly based on manufacturer part number by using the built-in database?
Thanks for the information.
Do you know how to install the extension (.wexb)?
Take a look - "Deploying/Undeploying a Windchill Extension": https://windchill-extensions.ptc.com/kb/articles/installext
