May 3, 2023 2:50 PM UTC
Windchill RV&S Gateway - Traces in Word Export
I'm trying to create a word export template for use exporting a MED_Hazard Analysis document.  I'm able to get most of the content without any trouble, but I have one piece I'm stuck on.
My document contains several MED_Hazard items, which have been configured with MED_Text and MED_Caused By fields.  The MED_Caused By field is the ID of a MED_Risk item.  Within the Traces tab of the MED_Hazard item I can view the details of the traced MED_Risk item, for example ID=000001, MED_Text=Risk 1.
My understanding of the structure within Windchill is that the MED_Caused By field does not itself hold any information about my risk, it is simply a number that happens to represent an item in the database.  Therefore in my Word export, when I use <%MED_Caused By%> I only see the ID of the risk, and can't find a way to access its MED_Text field.
Based on my example, what I would like to see in my export is:
Caused by: Risk 1 (000001)
Could anyone suggest how I might go about this? Or is it simply not possible?
To be clear this is not a question about the specifics of a MED_Hazard, MED_Risk or MED_Caused By nature.  This is a generic question about how to reference fields from a traced item.  The same logic applies to e.g. accessing the text field of a test case traced to a requirement.
Thanks a lot,
Hester
