Feb 21, 2020 7:20 AM UTC
Windchill SAML Authentication using InfoEngine Java API
I have setup Windchill Application 11.0 in SAML authentication mode.
I have used Shibboleth as Service Provider and ADFS as Identity Provider.
This SAML setup works fine on browser. I want to do same using my Connector DAO class using JAVA InfoEngine Connector.
I have used below code :
IeConnectionFactory f1 = new IeConnectionFactory();
IeConnectionSpec connSpc = new IeConnectionSpec();
Principal principal = new Principal() {
@Override
public String getName() {
return "uid=wcadmin,ou=people,cn=administrativeldap,cn=windchill_11.0,o=ptc";
connSpc.setAuthUser(principal);
connSpc.setProperty("ConnectionURL","https://vinw12wc25125.plugin.local/Windchill/servlet/SimpleTaskDispatcher" );
connSpc.setProperty("signRequests", "TRUE");
connSpc.setProperty("keyStoreType", "PKCS12");
connSpc.setProperty("keyStoreFilename", "C:/demo/user.pfx");
connSpc.setProperty("keyStorePassword", "dkpune");
connSpc.setProperty("certificateAlias", "useralias");
connSpc.setProperty("privateKeyAlias", "useralias");
connSpc.setProperty("privateKeyPassword", "dkpune");
javax.resource.cci.Connection windchillConnection = f1.getConnection(connSpc );
WindchillDAO10_2 dao = new WindchillDAO10_2(windchillConnection);
dao.Query("wt.part.WTPart", "name = Test1", null, new String[]{"*"});
catch (Exception e)
e.printStackTrace();
All certificate details provided are correct.
I get below exception trace :
Caused by: com.sun.org.apache.xml.internal.security.utils.resolver.ResourceResolverException: Cannot resolve element with ID header0
at com.sun.org.apache.xml.internal.security.utils.resolver.implementations.ResolverFragment.engineResolveURI(ResolverFragment.java:89)
at com.sun.org.apache.xml.internal.security.utils.resolver.ResourceResolver.resolve(ResourceResolver.java:313)
at com.sun.org.apache.xml.internal.security.utils.resolver.ResourceResolver.resolve(ResourceResolver.java:298)
at org.jcp.xml.dsig.internal.dom.DOMURIDereferencer.dereference(DOMURIDereferencer.java:114)
... 9 more
javax.xml.crypto.URIReferenceException: com.sun.org.apache.xml.internal.security.utils.resolver.ResourceResolverException: Cannot resolve element with ID header0
at org.jcp.xml.dsig.internal.dom.DOMURIDereferencer.dereference(DOMURIDereferencer.java:121)
at org.jcp.xml.dsig.internal.dom.DOMReference.dereference(DOMReference.java:430)
at org.jcp.xml.dsig.internal.dom.DOMReference.digest(DOMReference.java:364)
at org.jcp.xml.dsig.internal.dom.DOMXMLSignature.digestReference(DOMXMLSignature.java:496)
at org.jcp.xml.dsig.internal.dom.DOMXMLSignature.sign(DOMXMLSignature.java:379)
at com.infoengine.connector.IeInteraction.digitallySign(IeInteraction.java:492)
at com.infoengine.connector.IeInteraction.execute(IeInteraction.java:288)
at com.infoengine.connector.DataAccessObject.execute(DataAccessObject.java:187)
at WindchillDAO10_2.Query(WindchillDAO10_2.java:17)
at Test.main(Test.java:33)
Feb 24, 2020 12:32 PM UTC
I dont think native InfoEngine calls are designed to work with SAML/SSO Authentication.
Feb 26, 2020 4:41 AM UTC
Do you have any idea then how can we achieve this using Java API's ?
Feb 26, 2020 8:40 AM UTC
That's not how SAML/SSO is supposed to work. May be OAuth could be an option, but native InfoEngine doesn't support that too, and if someone have to design it, it may be a huge undertaking as the information flow is very complex.
The easiest way to do that is, use latest version of Thingworx Navigate 8.5, with OData connector which will allow making calls to InfoEngine services using SAML/SSO/Oauth.
