Jan 5, 2024 11:26 AM UTC
Windchill Shell is launch failing.
substr outside of string at windchill line 355.
Use of uninitialized value in hash element at windchill line 357.
Use of uninitialized value in scalar assignment at windchill line 357.
Use of uninitialized value in hash element at windchill line 358.
Use of uninitialized value in scalar chomp at windchill line 322.
Use of uninitialized value in index at windchill line 336.
Use of uninitialized value in substr at windchill line 336.
Use of uninitialized value in index at windchill line 337.
Use of uninitialized value in substr at windchill line 337.
Can't spawn "cmd.exe": No such file or directory at windchill line 383.
shussainiAnswer
Jan 22, 2024 12:48 PM UTC
Check if this helps.
Fadel
23-Emerald II
Jan 5, 2024 12:20 PM UTC
can you try steps in https://www.ptc.com/en/support/article/CS105560
Buiꓘa
Jan 5, 2024 12:34 PM UTC
COMSPEC at the system level is good. But no Luck!
Jan 5, 2024 12:21 PM UTC
Check out the following articles,
https://www.ptc.com/en/support/article/CS312422 - if it is a space issue
or
error logs mentioned above matches these 2.
Jan 5, 2024 12:36 PM UTC
Space Issue is mentioned for the Linux Environment.
Checked with IT and got no luck.
I am trying to find some other solution. Need some help.
Jan 17, 2024 5:34 AM UTC
Is there any other solution, or any idea why the shell is not working?
