Aug 17, 2023 8:01 PM UTC
Windchill startup issue
I am using Windchill PDMLink Release 11.2 and Datecode with CPS 11.2.1.8
Users unable to perform any operation in windchill. Search, create objects etc. Error in MS is tandardRequestDispatcher.dispatchRequest :: Runtime failure(s)
java.lang.NullPointerException
at wt.access.AccessSelector.getQuerySpec(AccessSelector.java:346)
Also if we stop a MS process, it is unable to come up with error
    paj1Answer
    Aug 18, 2023 10:28 AM UTC
    Actions.xml files are fine. A clean restart of the application worked and application is now up and running.
    However we still dont know the RCA.
    Any idea what would have caused this temporary issue?
    HelesicPetr
    Aug 18, 2023 7:22 AM UTC
    Hi @paj1
    can you provide full error from log? with the rows around?
    If you search for the error on the PTC knowlage base you could have found following article with your error
    CS381889 - Post upgrade unable to start the Windchill PDMLink 12.1
    PetrH
    paj112-AmethystAuthor
    Aug 18, 2023 7:49 AM UTC
    Hi @HelesicPetr ,
    Error is MS logs is.
    at wt.access.AccessSelector.getQuerySpec(AccessSelector.java:312)
    at wt.access.StandardAccessControlManager.getPolicyAcl(StandardAccessControlManager.java:2342)
    at wt.access.StandardAccessControlManager.getPolicyAcl(StandardAccessControlManager.java:4270)
    at wt.access.StandardAccessControlManager._hasAccess(StandardAccessControlManager.java:10719)
    at wt.access.StandardAccessControlManager.checkAccess(StandardAccessControlManager.java:7980)
    at wt.access.StandardAccessControlManager.checkAccess(StandardAccessControlManager.java:416)
    at sun.reflect.GeneratedMethodAccessor51.invoke(Unknown Source)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
    Also MS startup fails with error:
    [NmActionService.initXml] com.ptc.netmarkets.util.misc.StandardNmActionService.xmlInit - Started InitializeXML With stax Parsing
    FATAL [main] wt.method.server - MethodServerMain abort
    wt.util.WTRuntimeException: java.lang.NullPointerException; nested exception is:
    at wt.access.StandardAccessControlManager.hasAccess(StandardAccessControlManager.java:536)
    at sun.reflect.GeneratedMethodAccessor34.invoke(Unknown Source)
    at java.lang.reflect.Method.invoke(Method.java:498)
    HelesicPetr
    Aug 18, 2023 8:00 AM UTC
    Hi @paj1
    Check if you have any customization actions in customAction.xml or customActionModel.xml
    It seems that the the "com.ptc.netmarkets.util.misc.StandardNmActionService.xml" can not read some xml definition for Actions. There could be some xml parsing trouble,
    Try to check the xmls if they are correct.
    PetrH
