May 27, 2012 1:37 AM UTC
Windchill status = SITE NOT RESPONDING
Hello All,
I have a test server with WC10 which was working fine earlier. After 2 months again when i start the server, it gives below error:
Sun 5/27/12 06:55:09: main: INFO : wt.method.server.startup - MethodServer ready (in 129.75 secs).
Sun 5/27/12 06:55:12: wt.intersvrcom.SiteMonitor.timer: ERROR : wt.intersvrcom.SiteMonitor - Names=[master], URL=http://host-PC.localdomain/Windchill/servlet/WindchillGW, Status=SITE NOT RESPONDING, ResponseSeconds=1.06832684, TimeOfPing=2012-05-27 01:25:09.424
Sun 5/27/12 06:55:12: wt.intersvrcom.SiteMonitor.timer: INFO : wt.jmx.notif.siteStatus - Time=2012-05-27 01:25:12.674 +0000, Name=SiteStatusNotifier, SourceObjectName=com.ptc:wt.subsystem=Monitors,wt.monitorType=VaultSites, class="class" javax.management.Notification, type=wt.intersvrcom.SiteMonitorMBean.noResponseFromSite, userData=[averageResponseSeconds=NaN,lastPing=2012-05-27 01:25:09.424 +0000,lastResponseSeconds=1.06832684,lastStatus=SITE NOT RESPONDING,names=[master],numberOfPings=1,percentageUptime=0.0,url=http://host-PC.localdomain/Windchill/servlet/WindchillGW,vaultsAffected=Vaults "defaultuploadvault" contained in this site are inaccessible because site status is "SITE NOT RESPONDING".], message=No response from site "http://host-PC.localdomain/Windchill/servlet/WindchillGW", JVM Name=5064@host-PC
It says method server started. but, when i try to open the url, it will not even open the login page. in method server it says "SITE NOT RESPONDING". Please let me know how it can be solved apart from reinstalling the server.
Thanks and Regards,
Raghavendra
May 27, 2012 5:22 AM UTC
Please check the webserver port no. in wt.properties.
Praseeth M
> JVM
> Name=5064@host-PC
> Thanks and Regards,
> Raghavendra
Jun 13, 2012 9:11 AM UTC
Hello ,
If the site is a Replica Server , pls check if the WC services are up and running.
Sriram
Oct 15, 2012 7:08 AM UTC
Hi All,
Sorry for little late reply... Actually I found that Apache was not running... Now it is fine...
Thanks!
Raghavendra
