Oct 8, 2013 6:44 AM UTC
Windchill "undo" command
Does still exist the "undo" command in Windchill like in the old Pro/Intralink?
Because when I go in the "Events manager", in the slide menu on the top of workspace, only few events have the button "apply events" (in my case only the events "add") and anyway if I push one of those nothing happens in the WS.
Perhaps that command works only in a given situation?
At work I have version 10.1.
Regards
GregoryPERASSO
Oct 8, 2013 7:23 AM UTC
Hello
need to activate "frames" in your Workspaces
in Preferences/WorkGroupManager Client/Workspace Frame StackSize.
By default to 0. Set the number of "undos" you want to be able to do
regards
GregoryPERASSO
Hello
regards
Jun 6, 2019 2:19 PM UTC
Ok so I have frames set but how do you actually do the undo?
TomU
Jun 6, 2019 5:32 PM UTC
View all the events from the event manager and then click on the paper icon by the frame you want to apply.
https://support.ptc.com/help/windchill/wc110_hc/whc_en/#page/Windchill_Help_Center%2FCADxSrvrWspOviewFramesAbout.html%23
