Jan 5, 2015 6:30 AM UTC
Windchill Upgradation From 10.1 M010 to 10.2 F000
Hi all,
Good Day To You...
I'm trying to upgrade Windchill PDMLink 10.1 M010 to 10.2 F000. For this, I've gone through related materials provided by PTC and got some idea.
But, as I'm performing this task for the first time, I've been strucking up at some points.
I need step by step procedure to do this task in clear manner
Request you to provide your valuable information/steps for this task ( Feel happy if provide screen shots)..
Note : I'm using SQL SERVER 2008 R2 as database.
Thanks in advance.
Jan 6, 2015 7:01 PM UTC
I would recommend going to the latest build, 10.2 m020 and use the latest patch set.
I have found that doing an upgrade on a test server is beneficial and I build my own documentation as I go so I am prepred for the production upgrade. Can't help with 10.2 since I have not done mine yet and my base is 10.0 m040.
23-Emerald II
Feb 10, 2015 12:32 AM UTC
In addition to Ben's suggestions, the basic procedure to upgrade is documented in the Upgrade Guide:
http://support.ptc.com/WCMS/files/161692/en/WCUpgradeGuide_Source_10x.pdf
