Nov 7, 2025 4:16 AM UTC
Windchill upgrade manager issue
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.0.2
We are in process of upgrading our exsiting windchill enviorment ot version 12.1.2.0 , the OOTB Windchill 12.1 Ran successfully . later we performed below steps.
1. Import Source DB
2. "Run the DB scripts to fix the , Repository and file vault ,,Host names"
3. Import Source DS in Windchill 12.1 OpenDJ
4. "Compare and merge the site.xconf file from source to Target"
5. "Compare Rbinfo files on source and target and Add the additional entries"
6. "Move the customizations From source to target"
7 "Running the AddColumns Tool"
post above we Ran Upgrademanager from winchill shell. but it is throwing message windchill databse tables is allready upgrade . no action to be taken.
    Nov 7, 2025 8:01 AM UTC
    From Windchill 12.1.0.2 to 12.1.2.0, it is not a "Upgrade", it is a "Update" process. You can refe to the below Help Center process via PSI to update the existing system from 12.1.0.2 to 12.1.2.0:
    https://support.ptc.com/help/windchill/r12.1.2.0/en/index.html#page/Windchill_Help_Center/WCUpdateExistingIntallConfig/WCUpdInstall_PrepareWCMaint.html#
    avillanueva
    23-Emerald II
    Nov 7, 2025 12:38 PM UTC
    When you imported the source DB, it was to an empty DB right? It should not have any schema from the 12.1 install but should be a complete import of your previous version source DB. Is this the first or second rehersal? After any upgrade attempt, you need to revert 12.1 install area to a golden state before any upgrade changes were made. I suspect the Upgrade Manager is seeing hold overs from previous attemps in the database or localling in the application area.
    Emeritus
    Nov 14, 2025 5:11 AM UTC
    Hello @mprasad,
    It looks like you have some responses from some community experts. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
    Vivek N.
    Community Moderation Team.
