6-Contributor
Feb 24, 2022 1:18 PM UTC
Windchill WGM -- File not showing in Workspace after performing SaveBodies in SOLIDWORKS
After performing Save Bodies in SOLIDWORKS, the new/derived files does NOT appear in the workspace table of WGM
However, the files can be found when browse using File Explorer
The files will only appear if they are opened and saved again manually
What might be causing this issue?
Edit:
The same issue also happens when performing a Save As Copy
Oct 16, 2023 4:11 PM UTC
Did you find a solution for this issue?
I am running into the same issue.
ZWei6-ContributorAuthor
6-Contributor
Oct 19, 2023 12:48 AM UTC
No i did not..
HelesicPetr
Oct 23, 2023 8:38 AM UTC
Hi @ZWei
Have you opened TS Case ? I would open it.
PetrH
