6-Contributor
Jul 15, 2021 1:22 AM UTC
Windchill WGM File Sort Order (SOLIDWORKS)
We are storing our SOLIDWORKS drawing template file in Windchill Library
However, when the template had been moved to the Library the sort order got messed up.
The templates is sorted properly if the templates is exported to a local folder
Any reason why the sorting changed when the templates is moved to Windchill Library?
ZWei6-ContributorAuthor
6-Contributor
Jul 18, 2021 1:36 PM UTC
Update
It seem that the order changed whenever the file is checkout → update and check in
