Dobi
Oct 24, 2023 3:15 PM UTC
Windchill WGM with NX Viewer
For the multi-CAD users here that use NX, has anyone tried connecting NX Viewer to WGM?
Dobi
DobiAnswer
Oct 25, 2023 1:56 PM UTC
This is a little different. We use NX with Windchill and that works fine.
The NX Viewer is a lower-tier option (kind of like CreoView) that uses a much less expensive license. I reached out to tech support and it turns out NX Viewer connection to Windchill is not supported... much the same as CreoView wouldn't work with data in TeamCenter.
Oct 25, 2023 8:42 AM UTC
Take a look here - "Starting Siemens NX registered to Windchill Workgroup Manager , shows the WGM Authentification Window instead of starting the WGM": https://www.ptc.com/en/support/article/CS104974
Dobi
Dobi17-PeridotAuthorAnswer
