Mar 14, 2024 2:49 PM UTC
Windchill Workgroup Manager - Siemens NX CAM
Hi All,
we have got some problem with NX when the WorkgroupManager is on line.
Once the connection server is online NX lost the key to use Manufacturing Part.
The NX properties are ignored about NX Manufacturing template.
Template for part, assembly and drawing are ok. We lost only template for Manufacturing template
Any ideas about it?
Best regards
Gianpaolo
Community Moderator
Mar 22, 2024 7:26 PM UTC
Hi Gianpaolo,
Welcome to the PTC Community!
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Anurag
Apr 26, 2024 12:48 PM UTC
Hi these are the step to compare the different behaviour of NX once connected or not with WGM.
Step8 Setup part is created uncorrect linked .. refereced with some template part.png
Apr 26, 2024 2:40 PM UTC
The 4th and the 8th should have the same result.
