Jul 13, 2017 1:05 PM UTC
Windchill Workgroup Manager, Windchill File System Driver and Windows 10 Digitally Signed Drivers
If you have run into this, go ahead and nod in agreement (and sympathy). If you have not, and are looking to install or update Workgroup Manager software on Windows 10, be aware.  In my case, seen with SolidWorks 2016/2017, Windows 10 and Windchill 10.2 M30 CPS-24:
Windchill Workgroup Manager and WFS Driver Installation fails on Windows 10 when Secure Boot function is enabled
The PTC WFS Controller service does not work properly in Windchill Workgroup Manager integration with CAD Applications supporting Windchill File System (WFS)
PTC WFS Controller Service does not start and gives following error in event viewer "The PTC WFS Controller service terminated unexpectedly" in Windchill Workgroup Manager 11.0 on Windows 10
SPR 6593724
(disabling Secure Boot is not possible as a workaround in many organizations)
Probably other docs in the DB, but these were the ones PTC passed along. Hoping this gets a permanent fix soon!
Best Regards,
ML Starkey
Aug 30, 2017 1:12 PM UTC
Relief is on the way. CPS-25 is scheduled to drop on Sept 6th:
"The 10.2 M030 or 11.0 Windchill Workgroup Manager WFS Driver installation fails with error or the PTC WFS Controller service fails to start on Windows 10 when Secure Boot is enabled "
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS264835
TomU
Jul 19, 2017 12:12 PM UTC
Same issue with the Windchill 11.0 M030 workgroup manager.  Smiley Sad
2-Explorer
Dec 13, 2018 10:47 PM UTC
@TomU  Did you ever get your WGM working on Windows 10?
James
TomU
Dec 14, 2018 2:47 AM UTC
Yes, I believe I used the patched driver until a later CPS came out.  (That was a long time ago...)
Invisigoth1-VisitorAuthorAnswer
