7-Bedrock
Dec 13, 2022 4:33 PM UTC
Windchill WRS API - Can't add attributes to WTParts on creation
How can I add data to our custom attributes via the WRS API? We have an attribute for WTParts called "CAT_CODE" and I want to add data to it via the CreatePart command (http://##.###.#.##:##/Windchill/servlet/odata/v5/ProdMgmt/Parts). My data is:
 "DefaultUnit":{},
 "EndItem":False,
 "GatheringPart":False,
 "DefaultTraceCode":{},
 "PhantomManufacturingPart":False,
 "ConfigurableModule":{},
 "Name":"pyapitest",
 "Source":{},
 "AssemblyMode":{},
 "Uses@odata.bind":[],
 "DescribedBy@odata.bind":[],
 "References@odata.bind":[],
 "PartDocAssociations@odata.bind":[],
 "Context@odata.bind":"Containers('OR:wt.pdmlink.PDMLinkProduct:109352')",
 "Folder@odata.bind":"Containers('OR:wt.folder.SubFolder:155247')",
 "CAT_CODE": "52",
The error code I get when running the POST command is
{"error":{"code":null,"message":"'CAT_CODE' can not be mapped as a property or an annotation."}}
7-Bedrock
Dec 13, 2022 5:12 PM UTC
Ok, I had a couple issues with the data. The corrected data is:
 "DefaultUnit":{},
 "EndItem":False,
 "Name":partname + "_pyapitest",
 "Source":{},
 "AssemblyMode":{},
 "CATCODE":"520000",
 "Context@odata.bind":"Containers('OR:wt.inf.library.WTLibrary:110138')",
 "Folder@odata.bind":"Folders('OR:wt.folder.SubFolder:155247')",
The weird thing is that our IBA "CAT_CODE" can only be mapped when we remove the underscore and make it "CATCODE"...
TM_102006907-BedrockAuthorAnswer
7-Bedrock
 "DefaultUnit":{},
 "EndItem":False,
 "Source":{},
 "AssemblyMode":{},
 "CATCODE":"520000",
