Windchill9: Require report to display all objects which are related to ResultantPart in Change Task
I want to generate a Report/querywhich will list all the assemblies/endItems [upto the Root Node] for the Resulting WTParts listed in Change Task. e.g.
Assembly01
+--Part01 +--Part02
Assembly02
+--Part 01
+--Part02 +--Part03
EndItem01 [Product] +--Assembly01
EndItem02 +-Assembly02
Assembly03
+--Assembly01
+--Assembly02
ChangeTask01
+-- Resulting WTPart [Part01]
Now using the query attached If the Parameter given is ChangeTask01
I get results as
Assembly01
Assembly02
Which is perfectly correct. I want results which will list all the assemblies/EndItem [Up to Root Level]. The results should have been
Assembly01
Assembly02
Assembly03 ---[as Assembly01 and Assembly02 uses Part01, which are been used in Assembly03]
EndItem01 ------ [as Assembly01 uses Part01, which is been used in EndItem01]
EndItem02 ------ [as Assembly02 uses Part01, which is been used in EndItem02]
How to achieve this [recursive calling] usingReport Manager or any other way?
Didanyone had the requirementon similar lines ?
Sharing the solution/approach would assist
Pradeep Shinde
E-mail: -
