Jun 27, 2025 12:40 AM UTC
windchillDS要转换到openDJ
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.2
windchillDS要转换到openDJ上,根据技术文档操作,不成功,操作步骤如下:
1.在windchillDS上删除cnconfiguration,然后导出ldap
2.编辑导出的ldap文件,将“objectclass: ptcSubtree”全部替换为“objectclass: organizationRole”,然后保存
3.打开OpenDJ,点击New Base DN,新建Base DN 为o=ptc
4.单击导入ldap,将修改后的DS ldap导入进来
导入成功后,看不到用户列表。SCN:3R2577094
    Jun 27, 2025 4:41 AM UTC
    Have you referred this article .
    Jun 27, 2025 7:35 AM UTC
    During the Import data via Control-panel, you can enable the "Reject File" and "Skip File" log, see below screenshot, and then check the log files to see if there are any entries are skipped or rejected:
    Jun 27, 2025 11:40 AM UTC
    This will probably do it.
    https://community.ptc.com/t5/Windchill/who-is-using-V3-ldaps-other-than-WCDS11-2-for-windchill-12-0-1-x/m-p/793211
    Specifically...
    Migration is an export/import process.
    1. From WindchillDS Control Panel, export the remaining LDAP structure and EXCLUDE attributes entryUUID, createTimestamp, and creatorsName as these are read-only in OpenDJ and will not import.
    Emeritus
    Jul 4, 2025 3:32 AM UTC
    Hello @JH_8610616,
    It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
    Vivek N.
    Community Moderation Team.
