7-Bedrock
Sep 18, 2024 6:34 AM UTC
Windu
I am using Windchill PDMLink Release 11.0 and Datecode with CPS M030-CPS22
When we are executing Windu on Windchill M030-CPS22 all the Windu tasks are getting failed immediately.
Here are the errors that I faced
Task failed.
Wed 9/18/24 03:31:49: com.ptc.windchill.upgrade.updates.UpdateExecutionException: Error executing IncrementalUpdate Sequence Analysis (#SequenceAnalysis)
Wed 9/18/24 03:31:49: Nested exception is: (com.ptc.windchill.upgrade.updates.directives.directivesResource/39) com.ptc.windchill.upgrade.updates.DirectiveExecutionException: Method server code wt.pds.SequenceAnalysis.runDiagnostics failed. See nested exception for details
Wed 9/18/24 03:31:49: Nested exception is: wt.util.WTException: The user you attempted to login is not an administrator. The upgrade can only be run as an administrator user.
Wed 9/18/24 03:31:49: at wt.method.RemoteMethodServer.invoke(RemoteMethodServer.java:791)
Wed 9/18/24 03:31:49: at wt.services.LightweightServiceHelper.invoke(LightweightServiceHelper.java:165)
Wed 9/18/24 03:31:49: at com.ptc.windchill.upgrade.updates.directives.LightWeightServiceDirective$2.run(LightWeightServiceDirective.java:395)
    7-Bedrock
    Sep 18, 2024 8:09 AM UTC
    I'm able to exeucte Windu now and the tasks started or completed now.
    https://www.ptc.com/en/support/article/CS151715
    • Set in wt.properties: wt.auth.handlers=wt.auth.NullAuthentication,wt.httpgw.HTTPAuthentication
      and executed below command from Windchill shell
      windchill com.ptc.windchill.windu.Windu
    Sep 18, 2024 7:33 AM UTC
    Article - "How to run WinDU tasks for upgrade preparation in Windchill": https://www.ptc.com/en/support/article/CS71519
    HelesicPetr
    Sep 18, 2024 8:06 AM UTC
    Hi @BP_11893543
    You should use correct user that is the administrator in Windchill.
    the error mention it
    PetrH
    BP_118935437-BedrockAuthorAnswer
    7-Bedrock
    HelesicPetr
    Sep 18, 2024 8:18 AM UTC
    Hi @BP_11893543
    This is just a bypass the user login . U would recommend to set this property back after the WinDu will finish
    PetrH
