Jul 27, 2016 6:45 PM UTC
WinDu
Planning on a late year upgrade from PDMLink 10.0 m040 to PDMLink 11.0 m010.
When I go into WinDu. the only upgrade option is: Windchill 10.0 to 10.2 Pre-Upgrade Mandatory.
Is there a new WinDu that needs to be installed on top of 10.0 m040 that will perform the mandatory checks for a PDMLink 11.0 upgrade?
I have installed the following patches for WinDu/WinRu after I upgraded to m040:
10.0-M0X0_WINDU_WINRU_SUPPORT_PS5
10.0-M0X0_WINDU_WINRU_PS6
10.0-M040_PS7
HelesicPetr
May 10, 2017 10:40 AM UTC
You are not able to upgrade the system directly from Windchill 10.0 to Windchill 11.0
this path is not supported.
You have to first upgrade to 10.2 and then to 11.0
Hope this helps you.
Best Regards.
Petr Helesic.
BenLoosli23-Emerald IIIAuthor
May 10, 2017 1:52 PM UTC
You better check the references on this web page, because PTC says my planned upgrade is supported.
http://support.ptc.com/WCMS/files/35412/en/WCSupportedUpgradePaths_42617.pdf
