Sep 8, 2023 4:14 PM UTC
WinDU Freez
I am using Windchill PDMLink Release 11.0 and Datecode with CPS M030-CPS11
WinDU Freezes.
Tried suggested tech on PTC document, didn't work
Any suggestions?
    avillanueva
    23-Emerald II
    Sep 8, 2023 4:17 PM UTC
    Which document? Are you getting an out of memory issue or a very long running test? Which one's were executing when it froze?
    Sep 8, 2023 4:18 PM UTC
    Checking the Upgrade Essential box
    here is the case from PTC knowledge base
    Article - CS242299 - WinDU hangs in Windchill PDMLink 11.0 (ptc.com)
    Thx
    -Chirag
    Sep 8, 2023 4:44 PM UTC
    Did you get prompted for authentication already? If not, the authentication window could be in the background.
    Sep 8, 2023 4:48 PM UTC
    No it did not prompt me for authentication.
    I checked, nothing waiting in the background.
    avillanueva
    23-Emerald II
    Sep 8, 2023 5:19 PM UTC
    If you did not get prompted for authentication and did not provide authentication in the command line, its likely stuck there.
