Nov 1, 2023 1:13 AM UTC
Windu takes too long to execute Detect Missing Audites for Change Object workitems (8h)
I am using Windchill PDMLink Release 11.0 and Datecode with CPS M030-CPS22
The system needs to be upgraded to 12. When executing windu in 11.0M030, the following problems occur:
During the execution of windu, "Detect Missing Audites for Change Object workitems" remains Started for a long time (8h). Is this normal?
After the execution, you need help analyzing and solving the problems reported by the windu task;
Translated the text from Simplified Chinese to English using google translate
Subject: windu执行Detect Missing Audites for Change Object workitems时间过长(8h)
Body: 系统需要升级至12,在11.0M030中执行windu出现以下问题:
windu执行过程中“Detect Missing Audites for Change Object workitems”长时间(8h)处于Started,是否正常?
执行结束后需要帮忙分析解决一下windu任务报告的问题;
- By community Moderation team
    Rocket_Max
    Nov 1, 2023 2:03 AM UTC
    Hi @ZW_9537235
    If the data volume is large, this task is very time-consuming. The background of the task is to run this SQL:
    SELECT DISTINCT A0.classnameA2A2,A0.idA2A2,A0.classnamekeyB4,A1.classnameA2A2,A1.idA2A2,A1.name
    FROM WorkItem A0,WTUser A1
    WHERE ((A0.completedBy IS NOT NULL )
    AND (A0.status = @P0)
    AND (A1.name LIKE A0.completedBy))
    Please note that this task is not a mandatory upgrade task, so if your goal is to upgrade, you can skip this task
    Nov 1, 2023 5:40 PM UTC
    As mentioned, this is no longer a mandatory task. See PTC support article:
    https://www.ptc.com/en/support/article/CS194419
