Aug 8, 2024 1:47 AM UTC
WinDU Tasks Reporting Potential Problems : CabinetBasedDataContainerAlignmentReport
I am using Windchill PDMLink Release 10.2 and Datecode with CPS M030-CPS11
hello.
We are currently troubleshooting an issue with WinDU operation for upgrades.
A first party issue occurs in the CabinetBased Data Container Alignment Report in System Health Check during WinDU operation.
To fix this, I run Fix CabinetBased Data Container Alignment in Winru, but it only partially fixes it.
Here are the errors that I faced
CabinetBasedDataContainerAlignmentRT.log
Object in container Kis_Lib:38971109 Cabinet in container Kis_Project:82100010
Subfolder of object is in container Kis_Project while object is in container Kis_Lib:38971109.
There is not enough information to fix. Further investigation is needed.
VladimirNAnswer
Aug 8, 2024 8:40 AM UTC
Article - "WinDU task "CabinetBasedDataContainerAlignmentReport" reports "Container mismatch. Cabinet and Data are in different containers" in Windchill": https://www.ptc.com/en/support/article/CS19027
VladimirN24-Ruby IVAnswer
Aug 13, 2024 4:38 AM UTC
This was solved through a SQL query
