Mar 3, 2026 7:41 PM UTC
windy.MiscLogEvents has 19M records; Not purging automatically
I am using Windchill PDMLink Release 13.0 and Datecode with CPS 13.0.2.4
windy.MiscLogEvents has 19M records and DB has gown 100% in size in the last 3-4 months. CS178198 states to contact support if >10M records. Need assistance cleaning out the table and fixing maintenance routine to auto-purge.
Here are the errors that I faced
No errors; just table size issue.
    Mar 9, 2026 5:47 PM UTC
    The MiscLogEvents table exists so we can see MS Log file errors through the Server Status > Monitoring Tools > Log Event Histogram page.
    This article covers MiscLogEvents fairly well.
    https://www.ptc.com/en/support/article/CS42494
    The content of this table is intended to be temporary, and it is OK if the records are deleted.  More will be generated...
    So, I would start with cleanup.
    https://www.ptc.com/en/support/article/CS178198
    • Probably need truncate this table before enabling the schedule; because Database SQL cannot delete 10 million table rows
    https://www.ptc.com/en/support/article/CS411345
    As DB user:
    truncate table MiscLogEvents
    Then I would try to understand and correct the cleanup failure.  It could be a queues issue or something was blocking the cleanup.  Sometimes cleanup starts working just because you truncated the table.
    Community Moderator
    Mar 9, 2026 4:02 PM UTC
    Hi @PP_8422751,
    Thank you for your question.
    Anurag
    As DB user:
    Mar 18, 2026 1:17 PM UTC
    CS42494 covered my issue with both TRUNCATE and PROPERTIES file change to stop from repeating.
    Thanks for the assistance!
    PP
    Community Moderator
    Mar 18, 2026 10:15 AM UTC
    Hi @PP_8422751,
    Anurag
    Mar 18, 2026 1:18 PM UTC
    Yes, thanks!  Updated and marked as answered.
