Jan 4, 2012 12:58 PM UTC
WNC 10M020: How to prevent creating new objects in the root folder?
Windchill 10.0M020: How do we prevent users from creating new objects in the root folder of a product or library? They should be able to create in subfolders. I tried denying permissions for the default domain and granted permissions on a different domain then used it for sub folders, but the sub folders are also getting deny permissions. What is the best way to do this on Windchill 10M020?
OliverDroop
Jan 13, 2012 11:00 AM UTC
Deny permission is the strongest and can not be overwritten with grant on a lower level. Deny should only be used in very rare cases. All ACLs will be inherited from parent domains.
You can easily achieve this by removing modify permission for cabinet. That will do the job - all objects need to be stored into folders.
Default Domain of Context/Cabinet Object/TeamMembers/Read
Message was edited by: OliverDroop
22-Sapphire I
Jan 4, 2012 5:16 PM UTC
Don't attempt to control this via permissions. Instead, configure the OIR for each object type (e.g. EPMDocument) to a folder below root (e.g. /Default/CADDocuments).
Note: This is also an easy way to prevent creation of an object type in a specific Product or Library - don't create the specified folder. For example, we have a Library used for Patent Documents, and do not allow WTParts to be created there.
AJ_2224731-VisitorAuthor
Jan 5, 2012 12:04 PM UTC
Thanks for the post Mike. Seems like there is a problem if the folder that we specified in OIR is not existing.
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS36541
I also tried to direct into a folder which has restricted permissions, in the OIR, but then the location seems to be changing to the value of the "/Default" location.
OliverDroop
Jan 12, 2012 12:35 PM UTC
You should remove the write permission to cabinet object (like root for that context) in the default domain. Subfolder is a different object.
It might be that you need to add modify permission in the subdomain again - not sure how WC10 handles this meanwhile but first I would try without it.
