Feb 7, 2017 10:48 AM UTC
Worker Agent does not start
Hello All,
I'm trying to setup my worker to work with Solidworks. I get the following error in the logs:
[2017-02-07 11:35:28] workermonitor - Version : Creo 3.1 - M010 (13.3.10.27) i486_nt
[2017-02-07 11:35:28] Logging level set to 0x01.
[2017-02-07 11:35:28] Connecting to server "XYZ.com" on port 5600
[2017-02-07 11:35:28] Connection established
[2017-02-07 11:35:28] Got version 8 INIT  FAILURE (with no description) from WVS.
[2017-02-07 11:35:28] Monitor Shutting down.
The worker does NOT indicate "Fails to start" in the Worker Agent Administration page, it just stays off.
In sw2pv_config.exe, I have
- the setup directory pointing to the folder sw_setup
- Server Host & Server Port 5600: Failing the test, I get this message
Set keepalive ok
The CADAgent rejected the connection, is it configured for a SOLIDWORKS worker on machine WIN-9U6A5RRLNG0 (alias not set)?
What I've tried so far:
- Checked that the host name and port 5600 are correct
- Checked that the system does not run out of memory
- Checked for other forums with the same issue
Please help,
Ammar
2-Explorer
Feb 8, 2017 1:41 PM UTC
I think this is a problem with the hostname. The host name which your worker claims is not same as the hostname which you have in your agent.ini file.
Are you using a alternate hostname or shortname? If you are not using a shortname(just the hostname), try using shortname in your agent.ini.
On a sidenote, the localfilepath is incorrect, and this is not the reason of the error though- localpath=ftp:.
Feb 7, 2017 11:20 AM UTC
Hi Ammar,
After setting up worker directory on CAD worker, you will also need to configure CAD worker agent from CAD worker administration. If you already did this, then please hare you agent.ini file.
Also check if you have following property set in wvs.properties
<Property name="worker.exe.whitelist.prefixes" overridable="true"
             targetFile="codebase/WEB-INF/conf/wvs.properties"
             value="C:\|D:\|G:\|/|nohup /"/>
abaali1-VisitorAuthor
Feb 7, 2017 12:19 PM UTC
Thanks a lot for the reply Dipak.
My trusted prefixes are set correctly. Here is the content of agent.ini:
[agent]
transferpath=$(wt.temp)\transfer
port=5600
numworkers=1
[worker1]
localpath=ftp:
maxinstances=1
username=
prompt=
starttime=80
host=XYZ.com
password=
autostart=false
autoidlestop=
startfromlocal=FALSE
exe=D:\ptc\creo_view_adapters\sw_setup\swworker.bat
remotepath=
hosttype=local
port=601
distributed=false
autoerrorstop=false
availabletime=
shapetype=SOLIDWORKS
autobusystop=
Ammar
Feb 8, 2017 9:53 AM UTC
Hi Ammar,
Could you please share worker logs as well as CADAgents logs along with a screenshot of CAD worker?
Dipak
Feb 7, 2017 2:59 PM UTC
Feb 7, 2017 3:44 PM UTC
Not the same issue as what I'm having. My worker isn't failing to start it's just staying off. My host name is correct.
Any other idea?
Feb 8, 2017 5:04 AM UTC
The property "worker.exe.whitelist.prefixes" is case sensitive
             value="d:\|D:\"/>
Feb 27, 2017 6:56 PM UTC
For those with a similar problem in the future.. Solution was:
Enter in command prompt "hostname", and make sure the server in D:\ptc\creo_view_adapters\sw_setup\adapter.pvi and the worker administration configuration host have the same value as the one returned by the command prompt.
This value is not necessarily the Windchill URL (part in bold) XYZ.com\Windchill\app... It was the computer name...
Good luck,
Ammar
Apr 28, 2017 1:07 PM UTC
hello
            I am trying the same but my agent.ini file is still empty after configuring the worker agent.
Is agent.ini generates scripts inside it automatically when we configure worker agent OR we have to manually set the script in agent.ini file
let my host name is: test.com
so what will be exact values in wvs properties
i am getting the following values (worker.exe.whitelist.prefixes=C\:/ptc/creo_view_adapters/proe_setup)
and what about the second script , what is the exact script to execute  (worker.exe.whitelist.prefixes.<worker_host>)
please any one tell me the exact script to run with my host name
thanks in advance
Nimish
