Dec 19, 2019 2:15 PM UTC
Worker Agent doesn't start - process has exited unexpectedly.
I have some problems with PROE worker. In helper file I've got this:
Spoiler
Logging level set to 0x001 from command argument.
[2019-12-19 15:00:03] timestamps added to logging from command argument.
[2019-12-19 15:00:03] workerhelper - Version : Creo 4.0 - F000 (14.0.0.25) i486_nt
[2019-12-19 15:00:03] Increasing initial timeout to 180 seconds from command line to accomodate helper startup sleep time.
[2019-12-19 15:00:03] Connecting to server "XYZ.com" on port 5600
[2019-12-19 15:00:03] Connection established
[2019-12-19 15:00:04] Worker Cache Cleared
[2019-12-19 15:00:04] Started worker
[2019-12-19 15:00:12] Worker process 7824 has exited unexpectedly. Shutting down helper.
[2019-12-19 15:00:12] Worker helper shutting down.
[2019-12-19 15:00:12] WorkerHelper completed, exiting.
I have define correct host name in agent file and set whitelist prefix in site.xconf and wvs.properties. When I click the green flag status is still OFF and helper shows always "Worker process 7824 has exited unexpectedly. Shutting down helper.".
Thanks for help
Dec 19, 2019 2:22 PM UTC
Is your proeworker running on the publishing machine?
I have to manually start proeworker every day.
Once it is started, I can use Worker Agent to start Creo on the publishing machine.
Proeworker used to start automatically but ever since I went to CreoView Adapters 4.0 (now on 4.1) it has not and no one knows why.
MattPat14-AlexandriteAuthor
Dec 19, 2019 2:25 PM UTC
I have created it on the same server as windchill and creo. It doesn't start at all.
Feb 16, 2022 1:54 PM UTC
Hi, how did you resolve this if you don't mind me asking? I seem to have the same problem.
