Workflow Activity boolean Variable Required does not work
Guys,
I think the deal is that "Required" means the value cannot be null. In
Java a boolean cannot be set to null. It must have a value of either true
or false.
Therefore, in the case of the boolean variable "Required" will have no
affect.
David Graham
Windchill Developer/Administrator
CAx Administrator
Emhart Glass Manufacturing Inc.
Emhart Glass Research Center
123 Great Pond Drive | Windsor, CT 06095 | USA
Telephone +1 (203) 376-3144 | Telefax +1 (860) 298 7397
Mobile +1 (203) 376-3144 |
Boolean = null, true, false
boolean=true,false
right?
[cid:image001.gif@01CE9F4A.168256C0]
Steve Vinyard
Senior Solution Architect
dgraham-41-VisitorAuthor
Steve,
That is correct.
The reason it is correct is because:
Boolean is an "object" and like any "object" in Java it can be set to
null. The reason it can be set to null is that an object does not store
data. It simple points to where the data is stored.
boolean on the other hand is a primitive data type and like all primitives
in Java it can never be null. This is because primitives directly store
data.
This is why you can't code for example:
int i = null;
long l = null;
double d = null;
float f = null;
boolean b = null;
etc.
but you can code
java.lang.Integer i = null;
java.lang.Long l = null;
java.lang.Double d = null;
java.lang.Boolean = null;
etc.
Hope this helps
David Graham
CAx Administrator
