Feb 16, 2016 9:37 PM UTC
Workflow assignee question
I have been able to find some pieces of what is needed to implement this change, some questions remain I hope you can help with.
We assign a task to a Context Role which has a Group as its members. This assigns a Work Item to each group member and completes with ANY vote. We would like to capture the participant who completed a task, and replace the current Role participants in the workflow with that individual.
Here's what I know:
1. To Capture the participant who completed the Work Item: Task_Complete_User = (wt.org.WTUser)wt.session.SessionMgr.getPrincipal();  from Here
Here's what I need help on still:
2. How to Remove existing Principal in the Role
3. How to Add Task_Complete_User in to Role
I think I found it here
vmcdanielAnswer
Feb 17, 2016 6:29 PM UTC
Here is the code I'm using in the Complete transition of the activity. WC10.2 M030
try{
//SET COMPLETED BY
wt.org.WTUser Task_Complete_User = (wt.org.WTUser)wt.session.SessionMgr.getPrincipal();
if (Task_Complete_User != null){  //task1User is a wt.org.WTUser variable
  //System.out.println("Enter Set Team");
  //SET TEAM
  wt.team.Team team = wt.team.TeamHelper.service.getTeam((wt.team.TeamManaged) primaryBusinessObject);
  //System.out.println("Team is  "+team);
  //System.out.println("Enter Roles");
  //SET THE ROLES
  wt.project.Role  teamRole = wt.project.Role.toRole("Sourcing");
  //System.out.println("Enter Remove Participant");
  //REMOVE THE CURRENT PARTICIPANT
  wt.org.WTPrincipal removeUser = null;
  wt.team.TeamHelper.service.deleteRolePrincipalMap( teamRole,removeUser,team);
  //System.out.println("Enter Set Participant");
  //ADD THE PARTICIPANTS TO THE TO_ROLES
  wt.team.TeamHelper.service.addRolePrincipalMap( teamRole, Task_Complete_User, team );
catch(Exception e){
  System.out.println("Error in workflow expression");
   e.printStackTrace();
2-Explorer
Feb 17, 2016 12:07 AM UTC
Remote existing principals
  RoleHolder2 rholder = TeamHelper.service.getTeam(mTeam);
     Role rol = = Role.toRole("APPROVER");
        Enumeration enum = rh2.getPrincipalTarget(rol);
        while (enum.hasMoreElements()) {
            WTPrincipal user = ((WTPrincipalReference) e.nextElement()).getPrincipal();
            rholder.deletePrincipalTarget(rol, user);
Add Task Completed User back
List<WorkItem> wItems = WfWorkflowStatusHelper.service.getWorkItems(assignAct);
        for (WorkItem witem : wItems) {
            if (witem.isComplete()) {
                WTUser user = OrganizationServicesMgr.getUser(witem.getCompletedBy());
                rh.addPrincipal(rol, user);
Thanks you
Binesh Kumar
Medtronic - MITG
vmcdaniel1-VisitorAuthorAnswer
try{
//SET COMPLETED BY
  //SET TEAM
  //SET THE ROLES
catch(Exception e){
