7-Bedrock
May 15, 2019 7:00 PM UTC
Workflow expression and variables
I would like to find a method that could be used to reference a variable (using an expression that is in the ECN workflow) yet the variable was created during the ECR workflow.
The expression would look like the following:
If (mkt1)   {
                   If !  (marketing_nomore_1)       < this line is probably wrong since the variable exists outside of the        workflow
                   Result = “A”;
    Else
Result = “skip”;
The above expression is in the ECN.
mkt1 is a Boolean variable in the ECN.
marketing_nomore_1 is a Boolean in the ECR.
Thank You.
May 15, 2019 8:19 PM UTC
You will need to make the variable a global one outside the workflow in order to share it/use it in another workflow.
How does the ECN know what ECR it is to get the information from?
