Jun 28, 2012 5:11 AM UTC
Workflow Process termination by deleting the object..??
Hi all, I have a document and I linked the Lifecycle with the document to trigger a workflow....when ever there is a Set State to Under Review from proposal, the workflow process gets started......but the test messed up and resulted in ever growing workflow processes in a loop...nearing 50000, clogging system resources and degrading performance.... I could terminate the WF processes by Reassign lifecyle or change the state of the document BUT WC is giving exception of max search results threshold met..
Right now I am able to contain the growing workflow instances...by pushing it to reject state...from workflow tasks,,,
So my questions is, besides manual termination, if I delete the object , will it remove all the running processes from the system???
Please help me !!
Parveen
Dec 1, 2020 2:48 PM UTC
i think you have found it out by yourself. I had the same situation in the past and the short answer is yes.
