7-Bedrock
May 20, 2024 11:56 AM UTC
Working on multiple session parallelly
Version: Windchill Below 11.0
Use Case: I have a .net tool to check interference of models in CREO v 4.0 app using VB API. As of now we are able to work on single session but I want to work on multiple session.
Description:
I am able to open multiple session and getting the different session ID for both but when i am loading the assembly file for both session parallelly, Creo is getting  hanged or crashed and after sometime getting ToolKit error.
Can anyone suggest parallelism  supports VB API or not? if supports how to achieve this kind of scenario.
I am trying to work on multiple Creo session using single license.
HelesicPetr
May 20, 2024 12:03 PM UTC
Hi @swayam
Do you define a separated creo cache?
I haven't seen any issue if users works in parallel sessions.
PetrH
swayam7-BedrockAuthor
7-Bedrock
May 20, 2024 12:26 PM UTC
Thanks for your quick response.
No, can you guide me. How to define a separated creo cache.
HelesicPetr
May 20, 2024 12:42 PM UTC
Hi @swayam
Use The Knowledge Base search
CS62457 - How to use separate cache directories for Creo
Article describes how to do so
PetrH
Emeritus
May 27, 2024 4:47 AM UTC
Hello @swayam,
It looks like you have some responses from a community member. If it helped you solve your question please mark the appropriate reply as the Accepted Solution. If you found a solution yourselves, please document it in your topic and mark it as accepted solution. It will surely help other users who may have a similar question.
Community Moderation Team.
