Workspace Column Headers - Where are they?
- 0 replies
- 734 views
- Translate All
Hello, the following "workspace columns" have no header labels (Creo 5). I'm wondering if this is some setting or preference? If not, will this be resolved at some point? Metadata management is extremely costly and time consuming and this is one of the fundamental root causes. The other fundamental root cause is the inability to edit attributes in one location (e.g. some attributes can only be changed/assigned after check-in and some only when checked out). Thank you.
Workspace column headers with no column labels shown below and in the attachment image.
'sort by general status'
'sort by local workspace status'
'sort by out of date'
'sort by modified status'
'sort by compare status'
'sort by conflict information'
