WPA: validation for value restricted exemptions in Manage Compliance
In Windchill Product Analytics, on the Manage Compliance page, when applying exemptions, there should be a validation against exemptions which are value restricted.
For example, when applying the exemption “6(c) - Lead as an alloying element in copper containing up to 4% lead by weight”, the system should reject this exemption when the PPM exceeds 40,000.
Another example would be to reject exemption “7(a) – High Melting Temperature Solder > 85% PB” if the PPM is lower than 850,000.
