Sep 30, 2024 9:10 AM UTC
wt.doc.WTDocument:7784899724
I am using Windchill PDMLink Release 11.1 and Datecode with CPS F000
error "wt.doc.WTDocument:7784899724" during removing document DSH00008647 from many parts. we can't make any update to parts due this message error the same message when i launched loader remove link of document ( Message;partType;View;partID;partRevision;docType;docID;docRevision;partner;Link Removal The object with the following key was deleted or inaccessible: "wt.doc.WTDocument:7784899724";SupplierPart;;A300752500;;Datasheet;DSH00008647;;V501644--COFICAB TUNISIE SA;Yes )
    avillanueva
    23-Emerald II
    Sep 30, 2024 11:16 AM UTC
    I think we need more information than this. What operations occurred when this message appears? Screen shots? Based on what I see, it speaks to a broken link in the database. Is it some parts or all parts? Was there any manipulation of the database or customization running which could account for this?
    Oct 1, 2024 12:21 PM UTC
    hello,
    If possible, could you please organize meeting to share you the issue in our system.
    18-Opal
    Oct 4, 2024 5:56 PM UTC
    Hello AA_11007139,
    Is it possible to share the MethodServer log showing the error ?
    KR,
    Charles.
    Oct 1, 2024 2:11 PM UTC
    You should probably open a case with PTC Technical Support as they can use Teams and see your machine.
    The Community is a group of users helping other users and we do not have those tools available to us. If we do, I doubt any user will connect their system to yours.
