Jan 29, 2015 8:22 PM UTC
WT Document Types
Is there a way to "hide" document types that are not being used to lesson confusion? There are two OOTB types that I would like to disable or hide. They are subtypes of the main document.
Jan 29, 2015 8:32 PM UTC
In the Type and Attribute Manager select the Document Type and Edit from the Actions Menu. Scroll down in the upper panel and you will see an Instantiable Yes/No Attribute. Select No and Save.
Note - this will propagate to any sub-types so you will need to toggle any sub-types back to "Yes" if you want to use them.
