wt.load.LoadFromFile authencation failure
When executing TPI 147439, I am getting this:
Nested exception is: wt.util.WTRemoteException: Unable to invoke remote method
Nested exception is: wt.method.AuthenticationException
I had used LoadFromFile many times during my initial configuration of Windchill Intralink 9.1, and never had this problem.
However, that was before I enabled SSL/https, which I suspect is the problem here.
See https://www.ptc.com/appserver/cs/view/solution.jsp?n=147439
Example: windchill wt.load.LoadFromFile -u wcadmin -p wcadmin -d %WT_HOME%\loadFiles\uwgmcommon\preference.uwgm.xml
Any advice?
Gerry
