Sep 26, 2024 7:45 AM UTC
wt.manager.CacheMasterNegotiator - Reverting master to slave.
how to find the issue of wt.manager.CacheMasterNegotiator - Reverting master to slave. ?
2024-09-26 08:24:43,204 INFO [JMX client heartbeat 17093] wt.system.err - ???????? 26, 2024 8:24:43 ???????? ClientCommunicatorAdmin Checker-run
2024-09-26 08:24:43,204 INFO [JMX client heartbeat 17093] wt.system.err - ????????: Failed to check the connection: java.net.SocketTimeoutException: Read timed out
    avillanueva
    23-Emerald II
    Sep 26, 2024 12:38 PM UTC
    Not sure but need to see exact text of error (a bit more). Have you looked here:
    https://www.ptc.com/en/support/article/CS396018?source=search
    There is a want to increase logging output on that class.
