Oct 6, 2023 5:34 AM UTC
WT Part
Hi Guys,
I would appreciate your help finding a solution - I am working on WT Parts, and wherever I create a WT Part it's only stored in one Library, not in the same context.
Thanks in Advance,
Amir
Fadel
23-Emerald II
Oct 6, 2023 7:04 AM UTC
are you creating the parts using API ?
Buiꓘa
Oct 6, 2023 8:05 AM UTC
Thank you for the replay Mr. Fadel,
I tried to make a .class using eclipse for this & and i don't have an idea about API. Please brief on this.
Amir
Fadel
23-Emerald II
Oct 6, 2023 8:21 AM UTC
can you follow the same approach below for WTDocument, the same should work for WTPart :
String name = "TSTest";//name
String number = "TSTest";//number
String lifeCycleName = "Basic";//lifecycle name
String container_path = "/wt.inf.container.OrgContainer=demo organization/wt.pdmlink.PDMLinkProduct=Product-Test";//the container where the document will be created/located
String folder_path = "/Default";//folder path
WTDocument doc = WTDocument. newWTDocument();
doc.setName(name);
doc.setNumber(number);
WTContainerRef containerRef = WTContainerHelper.service .getByPath(container_path);
doc.setContainerReference(containerRef);
Folder folder = FolderHelper.service .getFolder(folder_path,containerRef);
FolderHelper.assignLocation((FolderEntry)doc,folder);
LifeCycleTemplate lct = LifeCycleHelper.service .getLifeCycleTemplate(lifeCycleName , doc.getContainerReference());
doc = (WTDocument) LifeCycleHelper. setLifeCycle(doc, lct);
doc = (WTDocument) wt.fc.PersistenceHelper.manager.store(doc);
Buiꓘa
