Sep 18, 2015 10:08 AM UTC
wt.util.WTRemoteException only in cluster environment when using windchill API
I have written a utility class in windchill and trying to access the methods of that java class outside windchill application using the below code.
url=http://<xyz.com>/Windchill;
RemoteMethodServer remoteMethodServer = RemoteMethodServer.getInstance(url);
  remoteMethodServer.setUserName(properties.getProperty(urladdress+".username"));
  remoteMethodServer.setPassword(properties.getProperty(urladdress+".password"));
//accessing the method of a utility class which is in windchill codebase directory
remoteMethodServer.invoke("getICNDetails","ext.abb.util.CNPendingTasks", null,argTypes,argValues);
I am getting the below exception only in clustered environment .
wt.util.WTRemoteException: Unable to invoke remote method; nested exception is:
        wt.util.WTRemoteException: Unable to locate method server; nested exception is:
        wt.util.WTRemoteException: Unable to get server; nested exception is:
        wt.util.WTRemoteException: Unable to locate server manager; nested exception is:
        java.rmi.ConnectException: Connection refused to host: <xyz.com>; nested exception is:
        java.net.ConnectException: Connection refused: connect
        at sun.rmi.transport.tcp.TCPEndpoint.newSocket(TCPEndpoint.java:619)
        at sun.rmi.transport.tcp.TCPChannel.createConnection(TCPChannel.java:216)
        at sun.rmi.transport.tcp.TCPChannel.newConnection(TCPChannel.java:202)
        at sun.rmi.server.UnicastRef.newCall(UnicastRef.java:342)
        at sun.rmi.registry.RegistryImpl_Stub.lookup(Unknown Source)
        at wt.manager.RemoteServerManager.acquireServerManager(RemoteServerManager.java:590)
        at wt.manager.RemoteServerManager.getServerManager(RemoteServerManager.java:564)
        at wt.manager.RemoteServerManager.remoteInvoke(RemoteServerManager.java:500)
        at wt.manager.RemoteServerManager.getServer(RemoteServerManager.java:281)
        at wt.manager.RemoteServerManager.getServer(RemoteServerManager.java:265)
        at wt.method.RemoteMethodServer.getMethodServer(RemoteMethodServer.java:1022)
        at wt.method.RemoteMethodServer.invoke(RemoteMethodServer.java:620)
        at ext.abb.dashboard.WindchillStatus.callRMI(WindchillStatus.java:135)
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
        at java.lang.reflect.Method.invoke(Method.java:483)
        at org.apache.el.parser.AstValue.invoke(AstValue.java:245)
        at org.apache.el.MethodExpressionImpl.invoke(MethodExpressionImpl.java:267)
        at com.sun.faces.facelets.el.TagMethodExpression.invoke(TagMethodExpression.java:105)
        at javax.faces.component.MethodBindingMethodExpressionAdapter.invoke(MethodBindingMethodExpressionAdapter.java:87)
        at com.sun.faces.application.ActionListenerImpl.processAction(ActionListenerImpl.java:102)
        at javax.faces.component.UICommand.broadcast(UICommand.java:315)
        at javax.faces.component.UIViewRoot.broadcastEvents(UIViewRoot.java:790)
Please do help me to fix my issue.
Archana
2-Explorer
Sep 21, 2015 12:54 PM UTC
Try creating a local hostfile mapping in the webapplication server directing the windchill URL to one of the slave nodes.
Thank you
Binesh Kumar
Barry Wehmiller
Sep 18, 2015 1:38 PM UTC
Hi Archana,
Could you let us know the Windchill version. Are you running this code from master server with only BGMS configured?
Bhushan
2-Explorer
Sep 18, 2015 9:50 PM UTC
Absolutely right, make sure you are running from a foreground node and also ensure that you have a cluster URL mapped to local IP in the hostfile so that the request won't get directed to loadbalancer.
Thank you
Binesh Kumar
Barry Wehmiller
