Aug 3, 2016 9:35 AM UTC
wt.util.WTRemoteException: Unable to invoke remote method;
Who can help me to solve this problem, my code is:
public class Test {
  * @param args
  public static void main(String[] args) throws Exception {
  URL url= new URL("http://whichen-ws01.cisco.com/Windchill");
  RemoteMethodServer rms=RemoteMethodServer.getInstance(url);
  rms.setUserName("wcadmin");
  rms.setPassword("wcadmin");
  System.out.println("login succeed!");
  Class argTypes[]={String.class, String.class, String.class, String.class};
  Object argValues[]={
  "Whichen_demo_name2",
  "Whichen_demo_number2",
  "Whichen_demo_file2",
  "C:\temp\rule.xml"
//accessing the method of a utility class which is in windchill codebase directory
  rms.invoke("createDoc", "com.cisco.whichen.DocManager", null, argTypes, argValues);
  System.out.println("Succeeded!");
My local host file is:
127.0.0.1 localhost whichen-ws01.cisco.com # whichen-ws01
Looking forward to your kindly help.
Aug 18, 2016 7:02 PM UTC
The package of this class is 'com.cisco.whichen2'. That means the class file should be copied into Windchill/codebase/com/cisco/whichen2/
Aug 8, 2016 5:09 PM UTC
Can you share the logs generated when executing the java file. Are you able to run it successfully if the file if executed from the server machine?
Bhushan
WhiteChen1-VisitorAuthor
Aug 12, 2016 2:38 AM UTC
I run it successfully in Linux environment, but my local test environment is WINDOWS7.
Below is the error info.
Exception in thread "main" wt.util.WTRemoteException: Unable to invoke remote method; nested exception is:
       wt.util.WTRemoteException: Unable to locate method server; nested exception is:
       wt.util.WTRemoteException: Unable to get server; nested exception is:
       wt.util.WTRemoteException: Unable to locate server manager; nested exception is:
       wt.util.WTRemoteException: Unable to locate server manager's registry; nested exception is:
       java.io.FileNotFoundException: http://whichen-ws01.cisco.com/wt.properties
       at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(Unknown Source)
       at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
       at wt.util.WTContext.getResourceAsStream(WTContext.java:3568)
       at wt.util.WTProperties.getServerProperties(WTProperties.java:965)
       at wt.manager.RemoteServerManager.getRegistry(RemoteServerManager.java:723)
       at wt.manager.RemoteServerManager.acquireServerManager(RemoteServerManager.java:587)
       at wt.manager.RemoteServerManager.getServerManager(RemoteServerManager.java:566)
       at wt.manager.RemoteServerManager.remoteInvoke(RemoteServerManager.java:502)
       at wt.manager.RemoteServerManager.getServer(RemoteServerManager.java:283)
       at wt.manager.RemoteServerManager.getServer(RemoteServerManager.java:267)
       at wt.method.RemoteMethodServer.getMethodServer(RemoteMethodServer.java:1022)
       at wt.method.RemoteMethodServer.invoke(RemoteMethodServer.java:620)
       at com.cisco.whichen.Test.main(Test.java:43)
The attachments is two method for remote method I got from the community, but both of them can't work in my test environment, please help me.
Aug 15, 2016 7:38 PM UTC
It's failing because of the below line:
This error is saying that it can't find the wt.properties file for the server. But, the above URL isn't the right location for wt.properties. It should be looking for http://whichen-ws01.cisco.com/Windchill/wt.properties‌ instead. The fact that it is using the wrong location makes me think there is some misconfiguration in your properties. What is the current value of wt.server.codebase in your wt.properties file?
