WTDocument Change Process
Hi All,
I am wondering how some of you manage change for your documents. We have several soft types of WTDocument and we want them to follow a change process that is different from other WTDocument soft types and from our standard ECN process. Is it possible to configure Windchill so that a specific soft type must follow a certain change process? I'm struggling to find a solution to this problem.
I could additionally soft type the CR and CN to configure the specific workflow but there isn't anything that I know of that will restrict the object types that can be in the implementation plan. For example I don't know how to force a document "Assembly Instructions" to be changed only by the "Assembly Instructions Change Notice" object and workflow. Make sense?
Patrick Williams | Engineering Systems | c: 616.947.2110
[cid:image001.jpg@01CE637F.994E1230]
