Sep 7, 2018 7:20 AM UTC
WTpart master attributes: default values not set when created by WGM
I have several WTpart master attributes with defined default values. The default value display mode is set to prepopulate.
When I create a new WTpart in Windchill, everything works fine.
However, when I create a new CAD document in the workgroup manager, which automatically creates and associates a WTpart, the default values are not set in the created WTpart.
Any hints how to solve this?
2-Explorer
Sep 24, 2018 7:59 AM UTC
What sort of CAD program are you using?  I use Inventor 2017 and we add the attributes to the CAD templates, once there they can be pre-populated or edited in the CAD object, then ported to the WTPart upon creation.
Jun 27, 2019 1:13 AM UTC
Was a solution found?
Chris171-VisitorAuthor
Jun 28, 2019 9:22 AM UTC
Unfortunately no solution found so far...we still have issues with WTpart default values.
Any hints on how to resolve this are welcome.
