Nov 19, 2014 4:28 PM UTC
WTPart Single Level Where Used Report in Query Builder
All,
I have a query builder report where I'm entering a child componet number and it's returning a where used list. The issue I'm having is that it returning where used for all revisions / latest iterationforthe child part. It's also returning all revisions of the parents that have usages as well. I'm looking for a way to do a where used on the latest revision / iteration of a child part and return only the latest revision / iteration of the parents. Doesn't anyone have some suggestions on how to get this type of information?
I'm also looking for a multi-level where used report that shows the child, it's parents, grandparents, ..... all the way to the top level. Is this possible?
Paul Sweet
Staff Engineer
UTC BIS Compression Technologies Group
Nov 19, 2014 5:37 PM UTC
Hi Paul, to get the latest revision of a part you will need to do a Sub-Select Criteria and then run a maximum on the revision identifier and make sure its all tied back. This has been done and is listed in some previous posts though I should be able to rustle you up sometime shortly and send over an example. Single level you can do easily enough. Mutli-Level is a whole other ball game in my experience. The best of these reports are typically done via InfoEngine Task that include QueryBuilder (WC Report Manager) queries. You’d have to navigate a data tree to go up or down to get all of the info which isn’t something QueryBuilder can effectively handle.
[cid:image001.gif@01CFCB30.A000F600]
Stephen Vinyard
Director of Customer Success
Nov 19, 2014 5:42 PM UTC
Here is a general report that will list out all CAD Documents but only the latest revision. Note that it also will not report on “Check out” copies. If you are just doing WTParts then I don’t think this is an issue though with CAD it would have otherwise reported on the “working copy” and shown a duplicate entry perhaps.
Nevertheless the sub-select is there.
Stephen Vinyard
psweet10-MarbleAuthor
Nov 19, 2014 8:58 PM UTC
Stephen,
Thank you for your assistance. It works like a charm.
Paul Sweet
Staff Engineer
Nov 20, 2018 1:44 PM UTC
Hi Paul.
could you share your QML? I´m looking to have child list from a parent WTPart.
Thanks.
MarcoTosin
Nov 20, 2018 1:54 PM UTC
Take a look at this document https://community.ptc.com/t5/Windchill-Tips/Resource-for-reporting/td-p/448738
There's a list of report ready to use (search in WTPart section).
This should be the report you're looking for https://www.ptc.com/en/support/article?n=CS72503
Marco
MarcoTosin
Nov 20, 2014 9:29 AM UTC
Paul,
if you are using query builder than take a look at this document I wrote on PTC Community.
It's very long and collect a lot of things I found here, in the Community and also article from Tech Support.
Hope you can find it useful.
http://communities.ptc.com/docs/DOC-6348
Marco
Marco
