May 7, 2015 5:34 AM UTC
WTpart subtype assigning while check in
How do I assign the sub Type of the WTPart that the EPMDocument will create and associate during Checkin? One way is to use a subtype of the epmdocument itself and assign "Default part type to Create", but I dont want to take this option. Kindly pour in your thoughts.
Iam using Windchill 10.2 with Creo 2.0.
For some assemblies , when checked in, i want to create Part subtype A, while for some other assemblies I want to create Part type B.
There is a clear rule for this on what conditions Part Subtype A or B should be created, but there seems to be no direct way to specify (as an attribute ).
Are there any preferences?
Thanks & Regards
Hari Varadharajan
Mar 17, 2016 3:24 PM UTC
Are you looking for something like this?
Selecting between WTpart sub-types when using auto-assciate
Mar 17, 2016 3:31 PM UTC
In WC11 you can do it OOTB. In WC10.2 you need to customize it with the auto association class. There is a setting in the preference manager where you can call your own class. "Custom Class for Auto Associate Part"
