Jun 11, 2021 5:08 PM UTC
WTPart to MPMLink Operation Where Used
I am trying to see what is available to perform a WTPart to MPMlink Operation where used.   can't seem to find anything useful.
Thanks in advance!
7-Bedrock
Aug 9, 2021 1:29 PM UTC
Try to use "Display Related Manufacturing Objects"
byork17-PeridotAuthor
Aug 18, 2021 2:04 PM UTC
@nelsonpereira  Where do you find that?
HelesicPetr
Aug 20, 2021 1:05 PM UTC
on detail page of WTPart
18-Opal
Aug 18, 2021 3:20 PM UTC
Check out this article. It might answer your question.
Article - CS350781 Is it possible to add columns to display "Attributes" of "parts", "Process Plans", "Operations" when "Display Related Manufacturing Objects" in Windchill PDMLink
Query Builder would work.
It is possible to create a Actions menu pick that will open a Report and automatically pass data derived from the object whose page the action was selected to act as inputs into the report.  This would effectively automate the running the report from the object's Info page.
Aug 18, 2021 4:50 PM UTC
@d_graham do you have an example of a query?
