8-Gravel
Aug 29, 2025 7:31 AM UTC
WTPart visualization disappears after check-out and doesn't regenerate after check-in
I am using Windchill PDMLink Release 13.0 and Datecode with CPS 13.0.2.3
We are experiencing an issue with WTPart visualizations in our Windchill environment. The problem occurs in the following sequence:
-When a user checks out a WTPart, the visualization immediately disappears (which may be normal behavior)
-The user then makes changes to classification or other attributes (not CAD geometry)
-After checking the WTPart back in, the visualization is not regenerated
Could you please advise on the correct configuration needed to ensure WTPart visualizations are properly regenerated after check-in when only attribute changes are made?
Thank you
    HelesicPetr
    Aug 29, 2025 8:35 AM UTC
    Hi @ZANET
    It is general behavior if the copy forward representation is disabled.
    Here is an article that describes how to enable copy forward representation just for the WTPart
    CS61223 - Viewables are not copied forward upon iteration in Windchill PDMLink
    Set following wvs.properties by xconfmanager
    publish.copyrepresentationsforward.restrict=true
    publish.copyrepresentationsforward.part.restrict=false
    Also check a Help Windchill Help - Copy Forward Properties
    PetrH
    Aug 29, 2025 8:30 AM UTC
    What kind of associations is it, between the CAD and WTPart, Owner, Image, Content, Calculated?
    HelesicPetr
    Hi @ZANET
    PetrH
    ZANET8-GravelAuthor
    8-Gravel
    Sep 1, 2025 2:28 PM UTC
    Thank you @HelesicPetr,
    my conf publish.copyrepresentationsforward.restrict was false.
    I've set these two others, and it works fine.
