8-Gravel
Nov 25, 2024 6:26 PM UTC
WVS Publishing Fails
Version: Windchill 13.0
Use Case: Need to check in part from worker machine to windchill. > On Windchill UI, under WVS Job Monitor, publishing fails. Encountered these errors from job log: - Error from Creo - Registration with server failed : Windchill license validation failed - CadAgent Returned: $ERROR$ Error from Creo - Registration with server failed : Windchill license validation failed
Description:
I have already followed this article Article - CS288647 regarding license requirement for CAD integration with windchill for the error messages listed above.
A PTC support questioned if CREO is able to open the part from the workspace and I am encountering crashes from opening the part (PTC Support hasnt contacted back). The part is a simple square extruded to make a box, nothing complex.
PTC article suggested to remove shade from config.pro but I dont have that listed within config.pro Article - CS222858.
Any ideas for either why the WVS Monitor fails or for CREO crashing from opening a simple part? - Are they even related?
jbailey
18-Opal
Nov 25, 2024 6:38 PM UTC
Are you using $USER in auth.properties?
8-Gravel
Nov 25, 2024 6:55 PM UTC
The auth,properties file is currently set up with only the wcadmin. Should I also include the test user that I am using?
If this is the case, then wouldnt this mean I would need to add all the CAD worker users username/password on the auth.properties file?
jbailey
18-Opal
Nov 25, 2024 6:57 PM UTC
No, using the wcadmin is fine. We had seen in testing if you used the $user variable, then every user would have to have a CAD license.
