Jun 2, 2026 10:23 AM UTC
WVS-Publishing issue/Job fails
Hello Experts,
We are facing an issue with 2D publishing in Windchill.
The user is working in a Creo environment and attempting to publish a 2D representation for a Creo assembly. The assembly contains a few child components that originate from SolidWorks.
When the user initiates the 2D publishing process, the publish job fails. We would like to understand whether the presence of SolidWorks child parts within a Creo assembly could be causing the issue and if there are any prerequisites or configurations required to support this publishing scenario.
Has anyone experienced a similar issue? Could you please advise on the supported approach and any troubleshooting steps to identify the root cause?
Any suggestions would be greatly appreciated.
Thank you.
BenLoosliAnswer
Jun 17, 2026 2:19 PM UTC
There are certain requirements for the CreoView Adapter that must be configured to work with Windchill and Creo. What version of Windchill, Creo and CreoView Adapter are you using?
If you are getting red marks on files on the publishing machine, be sure that bthe user assgned to do the publishing has full access in WIndchill.
18-Opal
Jun 2, 2026 11:00 AM UTC
Hi ​@AG_13010264,
What error is reported in the job log?
Jun 2, 2026 11:22 AM UTC
Above this normal came and after that error came from line which is below.
Failure to retrieve 0000009365.drw name 0000009365 (err = -4)
Jun 2, 2026, 4:44:43 PM:Drawing Processing Returned: $ERROR$ Failure to retrieve 0000009365.drw name com-uil-00209 (err = -4)
Jun 2, 2026, 4:44:43 PM:Attempting to delete temporary workspace publish11311129195403360877tmp.
Jun 2, 2026, 4:44:43 PM:Done deleting temporary workspace publish11311129195403360877tmp.
Jun 2, 2026, 4:44:43 PM:CadAgent Returned: $ERROR$ Failure to retrieve 0000009365.drw name 0000009365 (err = -4)
Jun 2, 2026, 4:44:43 PM:End (with Error): Drawing  - 0000009365.drw, A.2
Jun 2, 2026, 4:44:43 PM:End job (with error): Drawing  - 0000009365.drw, A.2
Jun 2, 2026, 4:44:43 PM:Publish Complete event dispatched
Jun 2, 2026, 4:44:43 PM:remove temp dir: $(publish.tempdir)\publish11311129195403360877.tmp
Jun 2, 2026 4:37 PM UTC
That says the publishing system cannot find all of the files needed to regenerate the assembly and drawing.
Jun 3, 2026 3:20 AM UTC
So, how to overcome this problem what all checkmarks is there we tried but still not getting the cause and solution.
Jun 10, 2026 6:40 PM UTC
Are you using a PDM system for your files or search paths to disk folders?
If search paths, be sure they have all folders needed. If a PLM, be sure the publishing owner has rights to all of the folders in a read-only mode.
Jun 16, 2026 11:25 AM UTC
Thank you for your reply,
yes, we are using a PDM system and we have checked all access modes also all are correct. However, when we checked the user system and viewed there are no red marks or error/warning indications, but the same in publisher system there we can find the red marks and warning indications. Is there any version conflict of creo and windchill visualization system?
BenLoosli23-Emerald IIIAnswer
Jun 18, 2026 7:10 AM UTC
Yes, we checked for version conflicts, tried the recommended versions, and now have a solution.
Thank you for helping!
