shussainiAnswer
Feb 4, 2026 10:54 AM UTC
As mentioned by Fadel, the MPMLink module is needed primarily for BOM transformation using the BOM transformer. Also, the module enables for Mfg. Process planning. For, transformation you will require the BOM transformation license. For creating process plans and other Mfg objects MPMLink module license will be needed.
Hope this helps.
regards
~Syed
Fadel
23-Emerald II
Jan 23, 2026 2:05 PM UTC
  • MPMLink Module introduces algorithm com.ptc.windchill.mpml.algorithm.ViewToLifeCycleAlgorithm
  • The class is inside the MPM JAR , so mpmlink is needed
Buiꓘa
Jan 23, 2026 2:44 PM UTC
will this be available also with BOM transformations?
Fadel
23-Emerald II
Jan 23, 2026 2:46 PM UTC
i don't really know what do you mean by BOM transformation , can you elaborate ?
Buiꓘa
