May 24, 2024 4:28 AM UTC
XML Code file changed
I am using Windchill PDM Essentials Release 11.2 and Datecode with CPS 11.2.0.1
The WT Booking XML Code file replaced and need to restore WT Initiation code file for Titagarah Server.
Link: https://titagarh-wc-prd2.ptcmscloud.com/Windchill/app/#ptc1/homepage
More Information
Earlier WT Number booking was 10 Digit and now its changed to 9 Digit.
Here are the errors that I faced
Earlier WT Number booking was 10 Digit and now its changed to 9 Digit., So New WT coming with 9 Digit and its not required,
Earlier 10 Digit Number is required for Project.
    HelesicPetr
    May 28, 2024 7:23 AM UTC
    Hi @SJ_11027292
    Check OIR rules how the number generation is set.
    PetrH
    Emeritus
    May 30, 2024 8:55 AM UTC
    Hello @SJ_11027292,
    It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
    Community Moderation Team.
